Originally Posted by lutach
The male plugs should have a very snug fit when going into the female and any slop would cause such a failure. So everyone make sure your male plugs are somewhat hard to push into the female to prevent this from happening. If the male plug comes off easily, carefully spread the contacts apart a little to give you that very tight fitting.
all males like a tight-fitting female.
well said lutach.
