C.H.U.D.
11.10.2005, 10:59 PM
Originally posted by MacII in another thread
Only trouble, my E is still setup for 5 mins racing. Even if I had the battery capacity my motor and speedo a very hot after 5mins. Cooling it would take some effort and likely some gearing changes.
Gearing is definately a huge factor and I don't see what your gearing is set at in this thread.
Your truck looks all aluminum, minus the CF battery plate. W/ the LiPo's installed what are you looking at for weight? I'm guessing 10-11 pounds.
A Feigao 10L has about 27 less oz-in torque than a Feigao 10XL when pulling 100amps. I think w/ the Kv and torque of the 10L, and the weight of your truck, this may be why you're running hot.
I don't know enough about Schulze to say how warm they generally run. I run a BK20120 because I wanted to make sure the speed control wasn't the weakest link...so it never even gets warm.
My Maxx, ready to race is 10.5 pds, I run 14 cells (gp3300 1.17, matched) w/ 18/64. My 2400XL will run 170 degrees w/o the heatsink, thermal grease, and 80mm fan. W/ the aforementioned stuff I run about 120-130 degrees. I get over 10 minutes+ runtime on a big fast track (http://globalservices.globalhobby.co...c.php?t=15061.). On WOT my truck will just barely pass a 1/8 buggy.
I think w/ a 9XL and proper gearing you'll easy run the 10 minutes w/ more than enough speed and a tough aluminum truck to boot.
Sweet pics and truck, btw.
