DRIFT_BUGGY
DRIFT_BUGGY's Avatar
11.03.2008, 08:41 AM
Well I think I worked out why the centre cvd shaft hits the servo mount. Because of the 46T Spur and the RCPD rear diff mount, the front diff mount has to run spacers to sit level which makes the shaft sit higher which causes it to hit the servo mount. I'll just use a dremel and cut it off to it no longer hits and test the buggy out tomorrow to see if it helps any
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
