danhfvcsd
11.03.2008, 05:40 PM
Originally Posted by bl-is-future View Post
dan that toe in your wheels shouldnt change no matter the position of the a arms. You have your toe links on top of the hub i seen in the picture. Try switching them tho the bottom and when you move the arm up and down the toe will NOT change.
ur such a champ man - I asked some questions about this on another forum and was told it was normal? -lol- Originally i thought it had something to do with the length of the TBs, as i had trouble fitting the FLM TBs they supplied with the arms, so i used the Lunsford TBs with the yellow GPM TB Ends, as they're a bit longer than the Lunsford ones i have...
Thanks for the heads up man, I seriously needed that tip hey! -lol- =) I'll get onto it this arvo, and update with results - thank you so much man!
