Thread: Enough said.
11.03.2008, 11:16 PM
No, you read right. It's common knowledge (or maybe not?) that twisting wires so they intersect as close to 90* as possible helps reduce noise. If the wires are kept short, noise is minimized (and would be hard to twist anyway). Personally, using a 2.4GHz radio along with keeping the antenna away from high current wires is plenty.
