crazyjr
crazyjr's Avatar
11.04.2008, 01:33 AM
Do you have any average numbers for the run?
I was only trying to say that a 1521 will be able to handle higher gearing for longer than the vtwin setup will. I know the vxl motor is decent, but is designed for a 10th scale 2wd truck. Plus it will get hot with alot of load, no way to get around its efficientcy. The Neu motor design is superior to a feigao. I am sure that a 1506 of similar spec will outperform the vxl motor.
All i ever really did was run for a minute or two, I never could secure the eagletree to do longer. Also, all runs were done on blacktop, with the first gen eagletree micro data logger.
I never said that the VXL was the best, The comment that the VXL could never see 1000 watts made me comment, I know it was peak, but it did
BTW, I'd never bet against a single Neu, of any Kind, When a V-twin was involved
