11.04.2008, 01:58 AM
Does the 9l have a 1/8 shaft or 5mm?
Should be a decent setup, gear for 35mph or so and the 9l should be fine. A heatsink is mandatory, and some cooling holes in the body won't hurt either. I hate fans, but you may need one, depending on outside temps. It is getting closer to winter so that may not be an issue till summer...
