Thread: Enough said.
brushlessboy16
brushlessboy16's Avatar
11.04.2008, 07:37 AM
Originally Posted by mikey09120 View Post
wait... twisting the motor wires limits interference?
did i misunderstand?
Motor wires are 7 1/2in long.. i tried braiding them- no avail, i even moved the speed controller to the rear chassis brace, no difference. receiver is on the front brace- as far away as humanyl possible from the noise
No, you read right. It's common knowledge (or maybe not?) that twisting wires so they intersect as close to 90* as possible helps reduce noise. If the wires are kept short, noise is minimized (and would be hard to twist anyway). Personally, using a 2.4GHz radio along with keeping the antenna away from high current wires is plenty.
do they have to be at 90 degree angles?
would braiding the three work?
Depends. How long are the wires? If they are so long you can braid them, then they really should be shortened IMO. I've never braided/twisted the motor wires and I have as much range as I can effectively see.
like as long as in the 4th picture of the very first post in this thread
Isn't that the truth!! Some people are never happy, no matter what, just keep telling yourself that...
beleive me its sticking strait up and as high up as possible
Would haveing the aluminum antenna mount hard mounted to the aluminum chassis affect anything?
