11.05.2008, 12:57 AM
the curve on my ramp is very mellow, you can do flips but it doesnt induce them just let off as soon as your airbrone and itll fly level. a flat ramp is no fun... and ramp like your thinking with alot of cuvre is not much good for other than tricks, that ramp is inbetween.
as for joining the the plastic ramps, cut one of the sides bottom lips off and then set it on top of ther others lip and the sides will be touching just drill a couple holes and use bolts with wing nuts. and with the sides touching you wont have that gap youd have just setting them beside each other. you wont need a 3rd one to join them.
last bit of off topic, we made 3 runs with my truck, got 390s hp an 840s tq im more than happy with it, and with the transmission they built for it will smoke the tires through 1st, 2nd, and then bark them in 3rd. and mine doesnt black smoke hardly ever, black smoke is wasted fuel....and like you said its not very appealing at intersections.
