hemiblas
hemiblas's Avatar
11.05.2008, 08:52 AM
I would use the novak heatsink. Its about 13 bucks and does wonders for temps. In winter I havent seen the feigaos heat up but the smooth can design just doesnt do a good job of disapating heat. . Generally running any vehicle in temps over 100 degrees is just not a good idea, but anything under that and I have been ok with my feigaos. I dont know if the RCM clamp will work as there is no extra space in front or behind the motor if you are going to run a 9L.
