Fyi
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Fyi - 11.05.2008, 10:10 AM
Just for future info next time you need bearing try going on line to VBX bearings. I found them a while back and ordered up some spares, because the price was way lower than most others and they have steel sealed bearings pretty cheap. After I received them I was very pleased with their service, their prives and the quality of their products, so I ended up purchasing more spares and they threw in a digital caliper for $10, which I now use all the time. I purchased like 200 bearings from them within a month to build up my stocks for my various projects and saved a lot of money. I also found out that VBX supplies a lot of the R/C companies with their bearings. The bearings are great and the price is right. So check them out if you need any more bearings. Good luck with that.
