Originally Posted by lxmuff
The esc is very smooth for what it is. If you do have cogging, look for your connections etc.
As far as what Patrick said....That's nice but with then MMM on Version 3 since this past May, they still may not have gotten all the issues worked out.
As far as the resistance question with the path of least resistance, if your battery side bullets are short to the heatsink and you plug in your battery with the switch on the controller off ..... the esc circuit is virtually open.
Yes it is smooth .... but compared to the MGM it could be better ;)
