11.05.2008, 04:04 PM
Originally Posted by Jabe View Post
as castle said, it doesnt matter if those plugs on motor side touch heatsink, so lets leave that side as it is.
but certainly do something about those battery plugs, as they will shortcircuit and will damage your batterys.
why cant they just replace those damn plugs with wires...
Huh? If the HS does happen to short against the HS, it would definitely matter. You'd be shorting the offending phases together and probably damage the FET(s). I don't think Castle is saying it's ok for the motor connections to touch, they are just saying they could not get the HS to actually short the phases.
But yes, I agree, get rid of those silly plugs and use wires instead. I think they want to use bullets because their CC-Nue motor will have wires with bullets on the end and will offer more of a plug-n-play setup as opposed to soldering anything.
Or maybe use solder-posts (like Mtronics) or thick tabs (like Novak) on the motor outputs instead since they will be smaller in diameter and have much less chance of touching the HS. That way, people wouldn't be soldering directly on the PCB...
