11.05.2008, 07:40 PM
I posted the following in another thread. If it IS accurate, and would be of use, I can add it to the calc:
Originally Posted by Me
BTW: I don't think speed scales like the size does. From what I gather from this page, the formula for finding scale speed is:
1:1 speed = SQRT(scale) X scale_model_speed
So, if your 8th scale RC does 60mph, that scales up to SQRT(8) X 60 = 169.2mph.
Similarly, if your 10th scale RC does 90mph, that scales up to 284mph.
If someone can verify this, I can add this to the speed calc.
Just want to make sure the formula is accurate...
While I'm at it, no one has any information about the following?
Originally Posted by Me again
What I DO want to add is an alert of some kind which will tell the user if they are geared too high. There is a point in gearing where the motor is not spinning fast enough per mph for smooth low speed/take-off operation (around 1mph). Looking back, it seems I set my vehicles up for around 1000+ rpm per mph and everything runs fine. I'd like to know if there is a good rule of thumb regarding this, but would also depend on motor size of course.
On a similar vein, GriffinRU had provided some input on this topic a while back with regards to the minimum motor rpm needed for adequate back-EMF pulses from the motor. The idea was dropped because my simple mind could not grasp what he was talking about, but I think it would be worthwhile to have this kind of data available.
