JaySki
JaySki's Avatar
11.06.2008, 09:59 AM
Originally Posted by Happywing View Post
OK, you leave the case closed....the fan or a fan blade breaks. Send in my MMM for a fan replacement? They will be busy at CC. If they didn't want us to open the case, they shouldn't have put the fan connector inside the case.
I don't really think that is for you to worry about.. they can build however they want. When/if it fails.. You send it in and get it fixed. It's pretty basic, and they have gone above and beyond in taking care of the issues.
If you look at MOST electronics, if not all, there are Warranty stickers on the seals of them.. stating "Warranty Void" if broken. They don;t want consumers toying in the stuff.
Do you crack open your Home Theater receiver to look for defects and fix/mod it? Probably not.
Just leave it alone... If it fries the fan due to the fan wires, then it's on them to fix. Everything else.. if it fries something due to the failure.. Talk to Castle and work with them.
Getting pissed because they are starting to push a normal policy.. is a bit silly.
