I think the following response
Originally Posted by JaySki
Yes, I do have one.. in fact 4 of them....
Helps explain this response:
I don't really think that is for you to worry about.. they can build however they want. When/if it fails.. You send it in and get it fixed. It's pretty basic, and they have gone above and beyond in taking care of the issues.
If you look at MOST electronics, if not all, there are Warranty stickers on the seals of them.. stating "Warranty Void" if broken. They don;t want consumers toying in the stuff.
Do you crack open your Home Theater receiver to look for defects and fix/mod it? Probably not.
Just leave it alone... If it fries the fan due to the fan wires, then it's on them to fix. Everything else.. if it fries something due to the failure.. Talk to Castle and work with them.
Getting pissed because they are starting to push a normal policy.. is a bit silly.
How about a little empathy for the average dude that only has one? How many races do I want to miss to do a VERY basic repair? Now that's silly...and yes, I would crack open my home theater to fix a fan. How about this idea. Fix it and THEN send them out?
