11.08.2008, 12:19 AM
You could try heating up the pinion. The metals are probably not the same, so will have different expansion rates and may be easier to remove...
I can try to heat it, but have no idea how to hold onto the gear. I could clamp it into the vice??? Then use a punch to tap the shaft out of the gear...
