JThiessen
JThiessen's Avatar
11.08.2008, 11:10 PM
Originally Posted by mikey09120 View Post
update:
i will be using the 2200kv combo from castle
im going to use the traxxas 2.4ghz radio
i will use these zippy 4s 4400maH
and two of these instead of a 5955tg
i will also be using the traxxas tubes in carbon black
Is that traxxas 2.4 radio even going to be available for purchase individually before chistmas?
I couldnt tell you anything about those servo's. Personally, I'd stick with the stock traxxas ones until you can afford to buy a single good one.
Also, If you are buying 4S batteries, you can ONLY run them in parrallel on the MMM - its only rated for 6S.
