JThiessen
JThiessen's Avatar
11.08.2008, 11:32 PM
Originally Posted by mikey09120 View Post
i hope the radio will release before otherwise i could try those glitch busters
i was thinking about staying stock but they cant be much worse than traxxas servos. better torque and speed. i want to save for a good single but i the 5955tg's are discontinued and replaced by the more expensive 7955tg and would need a programmer i think and an aluminum single arm. and as stated before im runnin them in parellel
Yeah, so why spend the money on these...at 19 bucks each, I can almost guarantee that they are not going to last, and highly doubt you will gain anything over the stockers. The single biggest issue people have with the stock ones is that they can get out of time, and work against each other. IHMO, you will only waste 30% of the money you could use for a single servo.
You dont have to purchase anything more than the servo to run it. You can just trim the unused arm off (or just leave it). You dont need the programming kit either - thats for flyers.
I'd listen to the other guys on the batteries....I think you might have a hard time fitting 4S in the tray. My brother in law has the 4S 4900 Zippy's, and if I get the chance, I'll see if they fit in the tray on the chassis I have.
