What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
11.08.2008, 11:47 PM
The stock drive pins are the same diameter as the hole in the top-shaft. You may need some Loctite/JB Weld -or- a larger pin if the hole was widened when you put the drill bit in there.
