11.09.2008, 12:24 AM
I haven't found the pinion yet. SDP-SI doesn't have them, neither does McMaster, and Kershaw would probably want $25 bucks for 1. I'm thinking since 5mm/32P pinions are abundant I might just have to find a motor that has a 5mm shaft and a 30mm bolt pattern and is no more than 45mm in diameter... Now, where would I find one of those???
Like I said, it would be easy to drill out a novak pinion, they are about 10 bucks. Can you get the existing pinion off the old motor, drill it out and drill/tap a set screw hole in it?
