CrazyCooydog
11.09.2008, 12:06 PM
Originally Posted by Electric Dave View Post
There is some confidence. Build it and I'll be you have major MFGs knocking on your door.
Personally I'm switching trucks next year from my dual pack truggy to a single pack truggy. So I'd want to see a system which can take a single 4s pack of about 5000Mah. Since most truggies and buggies use this type of power and almost all have similar layouts, designing one system may work (or with minor tweaks work) in almost all the standard conversions.
I beleive that is would have been the case a year or two ago,but the longer we wait for this system the more likely we will have a E-only class.
The design in question IS for single packs of same width/length but the height is open to what ever you choose for packs,be it 4s,5s,6s...or 3000mha up to the skies the limmit,or I should say the body.
Why could you just have a mandatory pit stop or 2 at say 15-20 min. intervals, repack your rides and the restart . If transponders are used, this could be done. It would also even the field on restarts and possibly make for more competitive racing.
this is not the way races are held,a pit stratagy is part of racing, and would only come into play in an enduro setting
Because that's just not how it's done. We are the minority at the track as a result we have to play by their rules for the time being and for 1/8th electric to really be viable we have to be able to race for 30 mins with a pit taking 10-20 seconds at most.
I agree! This is it ,do we forsee another season with the nitro's? As more mfg's come out with 1/8 E vehicles theres a better chance that we WILL have an E only class. Most I've seen use a two battery system, and I beleive it's because WHEN a sactioning body DOES set out rules, one will be hard cases only. At this time we only have 3s hard cases.
I think the swap would need to be down to not more than 10 seconds, even against the nitro's. currently here we have to " stop on the rail 5 seconds" for every stop the nitro's make. There is no exceptions for battery change...
EX: you only need to do one 10sec swap and two 5sec,in a 30 min main. this is not alowed
Our rules state 4stops@5sec= to the nitros 4@3 sec fuel stops.
I'm thinking this will be changed to 5 stops as bolth the E-guy's here finnished in the top 5 most of the time....so it's obvious that the 4@5sec stops are not fair
It is very confusing to me why we don't have a system like this in production all ready....I've seen some small mirricals made here on this fourm, this leads me to think that most of these convertions are sitting on shelfs,or out in the back yard playing on private tracks.
