11.09.2008, 03:56 PM
If you concider $140-180 cheap, then you need to give some of that $$$ to me...
I would suggest just using some plasti-dip around the connections, and a simple plastic screen over the esc when its installed; that will prevent moisture from entering the esc, and still allow airflow (the MMM barely gets warm with zero airflow, so that shoudlnt be an issue in winter when ambient temps are low anyway).
