Originally Posted by suicideneil
You dont need to read the whole thing, there are seperate sections relating to the different issues you are asking about.
2 + 2 = 4. Series doubled the voltage, parallel doubles the mah.
You will need:
A UBEC / BEC.
A capacitor equal to 25v 105*C low esr 2000-4000uf.
A series Y-harness for the 2x 2s lipos to be wired together IN SERIES.
Yes, you are stupid, now go away before I fart on your head.
If you skip to the lipo tutorial, it explains what you need to do, as does the BL upgrade section in the FAQs.
Its all good...
Oh no, not the stinky farty.
Obviously I'm retarded...
So, I think I have it... Diagram:
Isn't the capacitor included into the UBEC? I see some capacitors sitting on the board.
Then again, I'm stupidly retarded.
