11.10.2008, 07:12 PM
Originally Posted by mikey09120 View Post
hey linc,
if i send you a two 4s 4400maH packs with no connectors, can you make them into two 2s 8800maH packs with feamle traxxas connectors and black shrink wrap?
Should not be an issue. What brand packs are they? I would break them down into 2 sets of 4 cells and make the packs from there. The cells of each 4s pack are matched so they will make a good basis for the 2s2p packs you want. Pm me for info if you like. I have traxxas connectors and will set you up with a single 2s balance connector per pack. I also have black shrink...
