rchippie
rchippie's Avatar
11.13.2005, 07:53 PM
Originally posted by squeeforever
im talking about the one that uses a center diff and turns in into a truggy as well as, if im not mistaken, eliminates the stock center braces. hippie, which one do you have?
p.s.-i plan on running that chassis, center diff, waps .28, and flm hybrid bulks w/ 1/8th gears, and eventually integy type 3 pro suspension.
Squee yes the JT chassis that uses the center diff does eliminate the center braces it uses a top plate. You will like it its very strong and stiff. The one i have is for the stock tmaxx.
REAL MEN RUN BRUSHLESS
