rhylsadar
rhylsadar's Avatar
11.11.2008, 05:38 AM
Just bend the heat sink fins away from the bullits, put some shrink tube on them & run it.
that may not be enough in any case. sometimes the plugs touch the heatsink not only on the fins but also at the bottom plate of the heatsink. so you can not just slip some heatshrink around it after bending the fins away.
this is all interesting information. short the esc to burn away the plugs from the heatsink before you can use it properly....
bye
rhylsadar
______________________
Exercitatio artem paravit
rhylsadar at youtube
