rootar
rootar's Avatar
11.12.2008, 08:51 AM
you could do just as good of a job with a 12mm socket turned backwards on a 1/4" drive extension, youd just set the endbell on the table and make sure you barely start the bearing with it straight and then LIGHTY tap it a few times till seats all the way down making sure your going straight every time you tap it. the bearing puller is definetly nice and i cant argue with a free tool, but like whats_nitro said i doubt i would have bought one on my own.
Jerry i dont disagree with you, i completely understand, being an aircraft mechanic i have alot of custom made tools for certin engines and aircraft, prolly alot of which i might not ever use agian but i needed them that one time and maybe some time in the next 10 years ill need it again so they'll stay in my rollcab and when i do use or need them agian itll be worth buying them or making them in the begining........NEVER can have too many tools!
