JerryF504
I don't understand, but I don't think I like it.
JerryF504's Avatar
11.12.2008, 06:58 PM
Originally Posted by Edumakated View Post
If the charger is not registering, you will need to. Otherwise, charge through the balancer. The couple of times it has done this to me, I just standalone charge to get the voltage of the pack back up and then finish up charging through the balancer. Or you can try to let the balancer get all the cells back in life first before charging. It can take awhile sometimes though, so I prefer just charging without the balacner first.
I wouldn't charge without the balancer especially if the battery is that far out of balance. That will cause the high cells to charge to way over 4.2 volts possibly causing the pack to swell or catch on fire.
