JesseV
11.12.2008, 09:47 PM
Originally Posted by phatmonk View Post
Have to agree with BL RVO those motors cant run on 4s and 3s if your lucky.They are also hard on the ESC.I have experienced 1st hand how the less expensive motors can cause the MMMs to run hot even on 3s.I compared mine to my Neu 1515/1.5 on 3s.Nice conversion though.
Hmm, i have to disagree. :) Well maybe its because of the fan + extra heatsink, but the motor was 50-60C after driving. And I was driving inside, so the environment temperature was 20C+.
My pinion is 13t and spur 45t or 46t, so its not that heavy i think. I put low timing on ESC and low start power to keep the temps as they are now.
When I ran the motor outside, around 0C, the motor didnt go much over 20C :)
But yeah, compared to more expensive motors, these get much hotter I guess.
EDIT: The quality of these china motors also vary alot. Last 2800kv XL short circuited because some axle balancing epoxy kind of substance came off of the axle/magnet and went between magnet and coil. So some motors might also get hotter than others.
