Originally Posted by Arct1k
Only as mike doesn't sell these....
PM me for the rest of the number
robforsberg@wheelextensions.com
Sent: Fri 10/31/08 10:09 PM
To: chris
Hi, Thanks for your inquiry. The first thing I need to know about your CRT is does is use axle pins in all four axles? If so, what is the diameter of the pins and the axles? You'll have to give me a call about the Slash. 308-730-XXXX Thanks -Rob
-------- Original Message --------
Subject: Wheel Ext
Date: Fri, October 31, 2008 5:33 am
To: robforsberg@wheelextensions.com
The following was sent to you through RC Universe:
Hi - Just wondering if you could make 17mm adapters for a CRT .5 - There is a lot of interest at RC-Monster.com/forum for these.
Also 17mm adapters for slash.
Rgds
Chris
Sweet. Id buy a set of those too.
