11.14.2008, 09:33 PM
Originally Posted by traxxasbasher13 View Post
I was wondering if this motor would be ok to use in my Savage? I will hopefully be running 4-6S lipo. Will it over kill? How about a 70mm motor or would it over heat? Thanks for the help!
The 70 should be ok in a stock savage, but if you plan to go heavier the 80mm is a must. I would go for the 80 either way. 1600 kv is a good 5-6s motor, a bit slow for 4s, IMO.
