Originally Posted by pasan
I use dual packs in both my trucks. the e-revo has the pack secured inside the compartments with the wire coming out the side of the cooling vents which require disassembly of the vent itself to remove the pack. I don't leave the packs plugged in when not in use, just when i need to take a break. The e-maxx has its packs strapped using velcro straps and foam chock blocks. Neither setup allows for removal of packs with the body attached.
I beg to differ! I have an E-REVO, and you can ask Luciano if it's possible to change a pack with the body attached. One of my packs came out during the RC-M bash and it happened to be where he was marshalling. He put my battery back in and I was able to continue. The cooling vent does NOT have to be disassembled for removing or putting in a battery.
edit - By the way sorry for getting this thread off subject - and for putting my 2c in
