11.17.2008, 06:00 PM
That makes sense since if the scenario I posted is true. You are basically shorting the BEC-side battery, but since it is not a direct short (due to some wire/circuit resistances), the wire lasted a while.
The BEC is hooked to the most negative battery pack and is the one the LVC should be hooked to.
I'm not saying this IS true, but sure would explain what happened.
