DickyT
11.17.2008, 08:34 PM
Question for you...what rec. box is that? Sweet conversion!
Thanks! it is the Traxxas Slash rx with an aluminum antenna mount put in the top of it with o-ring on either side.
Yes Brian, I ran the steerin servo wire under the battery tray. I spent an hour with my dremel making a channel in the tray to run it through to ensure no rubbing.
