MetalMan
MetalMan's Avatar
11.16.2005, 09:57 AM
Originally posted by A4DTM
can you please elaborate? I got two 109d's and four polyquest cells with PCM's..
PCM guard is not a balancer. It only cuts the charge if any cell reaches 4.25v (or something like that). Since it won't balance the pack, there can still be overdischarge if the LVC is set.
Originally posted by ryanvm777
I bought 2 Thunder Power TP-205 Balancer Adapter. From maxamps.com. How do I hook them up? Or do I, since I have the Astro Flight 109 charger. I bought this charger becuase I thougt it would be the best for 18.5 volts. Most of the other chargers in that price range would not charge that big of a pack.
The Thunder Power balancer adapter should come already wired to the pack. This would allow the use of the TP-205 balancer.
The Astro Flight charger is good for the price (9 cells and 8amps). But, it isn't a CC/CV charger, it is a pulse charger. Most balancers assume that you will be using a CC/CV charger, as the is the standard charge method. They will get confused with the pulsing of the AF109 and could kick in at the wrong time (and potentially make the charge take longer).
