sikeston34m
sikeston34m's Avatar
11.22.2008, 09:30 AM
[QUOTE=hoovhartid;234936]I run it on 6s zippies(two 3s)....as it is, the kb45 has MAD power. I cant imagine 10s. way too much.
these may be good for 8s tho
http://www.hobbycity.com/hobbycity/s...idProduct=6418
or
http://www.hobbycity.com/hobbycity/s...idProduct=6503
Thanks Hoov,
I run a 6S 20C 5000mah setup geared 18/40 Mod 1 with a Medusa 36-60-1500kv. It's pretty quick.
I'm sure your kb45 setup is awesome.
8S would be too much for either of these setups, but that's where you change things around somewhat.
Maybe 1000kv motor geared correctly on 8S, then try to "tame" it some with Punch Control?
