blueb8llz
11.22.2008, 09:13 PM
for those of you that has a 3905, i suggest you guys check your center drive shafts as well. mine never twisted, but the allen screw, is always loose after every run!
so maybe its because the allen screw is loose, which causes it to twist. for some reason, its only the center driveshaft....all the other driveshafts screws never needs tightening.
the driveshaft im talking about, is the one where you tighten from the top of chassis (that little hole in front of the gearbox) i have the rpm center skid plate.
