11.23.2008, 12:13 AM
That's the whole point, isn't it??
You got it! I just realized that the taller aftershock tires will up my speed a bit which is good. I found it more capable in 2nd gear, the motor seemed to make a bit more power with the increased load. I guess the gearing was a bit low for it in 1st. The taller tires should cure that, hopefully.
