lutach
lutach's Avatar
11.23.2008, 11:38 AM
Originally Posted by mohanjude View Post
James
I asked the forum on help with my damaged 1521 rotor. I applied epoxy on the magnet and it worked. However I got scared as after a 5 min run when I took the rotor out the epoxy was getting soft. I remember somebody talking about heat resistant epoxy. Dont know where to find the stuff. The epoxy you used on your picture is exactly the same stuff I used. Dont know if it will soften once the rotor is spinning at 30k rpm and the heat is high. Last question - do you think you will have enough clearance?
Mohan
Mohan,
You can find some info here http://www.solarcomposites.com/compo...itespools.html and http://www.solarcomposites.com/compo...20sleeves.html. Send them an e-mail and ask them what epoxy they recommend.
Regards,
Luciano.
