11.24.2008, 04:41 AM
Originally Posted by Tempted View Post
You could also run the rotor off of a low speed motor or lathe once you get the epoxy done. It would prevent running and may even help with balancing.
I just use enough epoxy to coat the thread. My main issue is how to balance the rotor once the wrap is done...
