Yep, thanks again for your help, seems to be all good now, except these temps. I'm going to solder the motor wires to the ESC tomorrow to eliminate the connections as the problem, i really dont want to have to cut another motor mount
Any tips to doing this? Do i just hold the wires together and solder them or should i wrap them together somehow?
What timing and PWM frequency settings do you run? at the moment my motor timing is set to auto and have the 8kHz frequency set. As for the fans, when i do run with the body, the ESC only clears by milimeters, so fans would have made mounting even harder.
Good to hear about the batteries, it was the first full charge i had put through them, so ill try get a couple more this week and see if them come to life
