superlightmaxx
superlightmaxx's Avatar
11.24.2008, 04:07 PM
thanks lincpimp! that's what I tought also about the L cans! not high enough kv to use only 2s. That's why I choose 8s because I want to run 2s and have a good set-up... so 35000rpm seems the ideal choice
I tought I would gear it for about 40mph and see from there...
I tought of a 24/72 pinion/spur combo gives me 14.7 ratio
with 5.5" truggy tires should be ok
What do you guys think?
Is that gearing to high?
Working on:
Twin CF GorillaMaxx (8S motors on 2x2slipo)
2WD AL. GorillaMaxx (7lbs with batteries)
