11.24.2008, 11:50 PM
Which solder did you use for the bullets? You can just re-shrink the MGM. Make sure to hold the lighter as far away as possible so you don't fry the internals. Why not retrofit your motormount to be adjustable? Why would you (in your right mind) gear so high?
