11.25.2008, 10:17 PM
I have to think you have something else going on here. What kind of "wear" did you see that made you concerned? Are the shafts rubbing on the arms? Did you change your rockers and pushrods to the correct ones for use with the extended wheel base arms? (you can't use the LT's with those, right?). You have a symptom that may or may not be resolved with higher priced CVD's, but you may also end up spending that money and still have the issue.
BTW: If you have seen any of Jerry's stuff, he has an extreme allergy to anything plastic!!!!
I have been running my revo with all its plastic day in and day out on 6S, and they have been holding up better than my metal CVD's did.
