sikeston34m
sikeston34m's Avatar
11.26.2008, 03:53 PM
So here is the next incarnation of the 6x6! Now it has an axi 2826/12 760kv outrunner. Using 14/72 gearing and it seems to be about right. I think I will play with the gearing a bit to get it just right. Also check out the 1/4 scale front steering servo, plenty of power there. I also repaced the rear servo with a hitec 5997tg servo for added power. I have the aftershock wheels/tires, but I want to remove the front tires from the wheels and add some weight. Still a blast to play with, easily goes anywhere I want, even thru foot deep grass!
Isn't the torque of that little motor incredible? So much in such a small package.
I'm sure you could up the gearing some if you want. Even with the additional weight and the additional drivetrain of your creation.
Looks great! Can I drive it? LOL
