Originally Posted by tc3_racer_001
when i hit my cutoff for zippy 4800's i can only put around 3300 back in. (3.2v cutoff)
so im not sure how they get their 4800mah rating?
huh maybe the zippys arent all that and a bag of chips. because if they rate a pack for 4800 and it only holds 3300-3500mah after you dump it then that in my opinion is a 3500 pack because thats the usable amount of capacity it has right? i know when i dump my protek 5s4000s (20 minute main) they read 15.5 volts going on the charger and hold 4100 mah and 21 volts
so im getting a full 4100 mah of capacity out of my 4000 5s lipos and your getting 3300-3500 mah of capacity out of your 4800s???????? that sounds bad
