11.29.2008, 02:08 AM
Well, the rating has to be for what you can use. The capacity of the lipo 3v and below is irrelavent. So the rated capcity would be from 4.2v to 3v. Every lipo I have used has generally been good for its rated capcity, as long as it was used within its discharge capabilities. If you push a pack beyond its cont c rating then you may not get the full discharge out of it before it hits the lvc. That was my issue with maxamps 3000, 4000, 5000, and 10000 cells.
