MetalMan
MetalMan's Avatar
11.30.2008, 04:13 AM
Success! I maidened the truck today: first impression was that this motor is very loud! The tones it emits due to the ESC attracted quite some attention, but once rolling smoothly this truck is rather quiet.
Specifications:
-entire polycarbonate chassis, heated and bent with a propane torch. The two side plates were made together to ensure exact precision.
-HPI MT2 18SS front end with aluminum differential housing, aluminum knuckles, carbon fiber shock tower, and GS Storm 1/8 buggy front shocks
-HPI Wheely King rear axle with RC4WD straight-axle adapters, custom c-clamps for mounting of the 4-link suspension, STRC widener kit, and Ofna Super Shocks
-front body mount was cut from 3/8" thick polycarbonate and the posts are cut-down Slash front body posts
-rear body posts are for the Duratrax Nitro Quake
-the FLM aluminum bellcrank for the Rustler was fitted, along with 5x8mm bearings
-Airtronics 357 servo and Kimbrough Gas Truck servo saver
-any colored standoff/post on this truck was made by Axial (these things are awesome!)
-clear standoffs/posts are 1/8" ID and 3/8" OD polycarbonate tube tapped to 4mm
-front bumper mount is an aftermarket piece made to allow the MT2 to accept a Revo bumper, so I fitted a Slayer bumper which required minimal spacing
-the rear bumper is from a Slash, but the bottom mount was bent with a propane torch and the top mount was flipped
-lower links are T-Maxx or Revo steel steering turnbuckles, upper links are Revo steel pushrods
-the driveshafts are cut-down Maxx driveshafts
-Slash nerf bars
-STRC 14mm hex conversion for the Rustler/Stampede, with the wider hexes in the rear
-Slayer wheels/tires all around
-Proline Hardcorr body
-MM ESC straight from CC with CCBEC
-initially using 2x 3s 2100mah Impulse 16C packs in parallel
-2x Neu 4s 2100mah 30C packs just came in, and those will be in parallel for 4s 4200mah 30C
If I missed anything, just ask .
This truck has interesting handling thus far - the rear shock oil (45wt) is too thick, and the rear needs a sway bar BADLY. Right now when I pitch the truck the chassis leans, and leans for too long after pointing the truck in a straight line. This is no doubt the result of the shock oil not allowing for a quick enough weight transfer, and will be fixed. In the soon-to-come pictures you will notice the torn up overspray film on the body, please ignore that . And now, for the build pictures:
(Note that these are older)
