Metallover
RC-Monster Spudgunner
Metallover's Avatar
11.30.2008, 02:32 PM
Originally Posted by Byte View Post
So first I will try what the speed will be with a Mamba-25 and the 8000kv motor (And I guess I won't get 62mph with stock gearing)
The next step will be a MMM and the 8000kv motor.. (Just to see the difference between the mamba-25 and MMM)
And the last step will be purchasing a NEU, and finally get 62mph
@Metallover: This vendetta is yours I think? http://www.youtube.com/watch?v=S32YX...eature=related
Could you say me what motor is in it? On youtube it says: "Neu 1107/1.5D" but that motor doesn't exist?
EDIT: The only problem is a 3S LiPo.. I can't find a good one, that will fit.. :(
Thanks!
The motor is an 1107/1.5d that is 8500kv. I purchased it from a guy on here slightly used. I'm guessing Neu stopped making that motor or he got a special wind. If you are running 3-4s you can't use that motor.
If you are doing speed runs you have to improvise on battery fitting. A lot of people have custom chassis to fit everything. I think you can put one in the battery tray and one perpendicular to the first one above everything else. The mmm will make it more of a challenge...
